It is currently Thu Oct 22, 2026 9:29 am
 Post subject: Right or wrong?
PostPosted: Wed Jul 03, 2002 12:03 pm
I have a MP 4120243 cam. Have checked installed cntrline it is now at 101 degrees. Zeroxed sheet that came with cam has 102 installed, this sheet has 3 slants and 4 v6's listed. Engines book and MP catalog 1999, both have 108 installed for same cam. My question, which do I use? Thanks for any help.
t110@pennswoods.net
PostPosted: Wed Jul 03, 2002 12:54 pm
: I have a MP 4120243 cam. Have checked installed
: cntrline it is now at 101 degrees. Zeroxed
: sheet that came with cam has 102 installed,
: this sheet has 3 slants and 4 v6's listed.
: Engines book and MP catalog 1999, both have
: 108 installed for same cam. My question,
: which do I use? Thanks for any help.
I have also seen all these different listings for Mopar installed C/L.
If you still have the degree wheel out, I would take a look at how well the overlap event centers or "splits" over TDC exhaust at 102 and 108 installed. (108 sounds like the lobe seperation number)
If you want low and mid range performance, shoot for at least an even split, if not a few more (2-4 degrees) of intake overlap event prior to TDCE.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 24 guests
