It is currently Sun Feb 23, 2025 12:09 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sun Sep 02, 2007 11:29 am
I have round glass pack looking turbo mufflers on my slant. Seamless and the exhaust guy said they last a long time.
They drone between 55-70 mph with an H pipe. 70+? quiet!
X pipes require lots of dyno and AFR etc testing. H pipes just get it as far forward as possible.
H pipe cut the noise some.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sun Sep 02, 2007 12:23 pm
Sandy, I suspect your rear pipe is just enough shorter than the '67 and up A bodies to have a different resonant frequency. That plus maybe the over dirve tranny puts you at a lower RPM at cruise. Maybe even the tune on your engine has something to do with that. I discovered that the leaner mixture at cruise made less noise. And, timing effected the exhaust note as well.
Sam
PostPosted: Sun Sep 02, 2007 1:22 pm
....I think its the larger muffler.
PostPosted: Sun Sep 02, 2007 1:58 pm
I always wanted to do a 6 cylinder version of the Formula S chambered pipes with resonator.
Which chambered pipes? The Formula-S cars got ordinary exhaust systems with ordinary reverse-flow mufflers...and a resonator in the tailpipe with a racy-lookin' big square angle-cut outlet end. I think Ford experimented with chambered pipes for a couple years.
PostPosted: Sun Sep 02, 2007 4:23 pm
IIRC 302 Z-28's could be bought with headers in the trunk, and chambered pipes. '69 or so?
PostPosted: Sun Sep 02, 2007 8:47 pm
An harmonic(a): What's that from?!!!
Yep. Been watching MASH reruns too often!
:mrgreen:
Users browsing this forum: No registered users and 22 guests
