It is currently Thu Oct 22, 2026 7:20 am
PostPosted: Thu Jul 04, 2002 9:32 pm
Just wondering. I've been trying to put the setup Wayne used to use (shown elsewhere on this site) on my Dart, and it's been slow going, mostly because I haven't had that much time when I can work on it. Anyway, I'm just curious as to how many people have built engines like that. Does anyone have a ballpark figure for how often this has been done?
PostPosted: Thu Jul 04, 2002 10:39 pm
: Just wondering. I've been trying to put the
: setup Wayne used to use (shown elsewhere on
: this site) on my Dart, and it's been slow
: going, mostly because I haven't had that
: much time when I can work on it. Anyway, I'm
: just curious as to how many people have
: built engines like that. Does anyone have a
: ballpark figure for how often this has been
: done?
Seems like quite a few are going this route. I have always been fascinated by turbos and their potential, but never really tried to build a combo with one. This time I am commited, and with all the info and help available on the web, it will become a reality.
Tom
sschultz@telusplanet.net
PostPosted: Fri Jul 05, 2002 3:08 am
: done?
I have an older setup in my garage just waiting to go in my 63 Dart Convert. It came out of a 69 van.
Chuck
webmaster@omnipages.com
PostPosted: Sun Jul 07, 2002 9:16 am
I run a turbo on my slant six. You can go to
<A HREF="http://home.earthlink.net/~mrdartgt/">http://home.earthlink.net/~mrdartgt/</A> or
wangermotorsports.net I do not have pic of the new setup on there but some of the other thing that I did are on there. I make costom turbo kits for alot of other types of cars to. I got a stock engine to go 14.50 @ 95 mph, that was intercooled and at 10 lbs of boost. I have got a new engine built up with turbo cam ,head work, But I needed to get a bigger radiator so I am running 4 lbs until I get a new intercooler. The new engine ran 15.06 @ 90 at 4lbs. The tranny was sliping pretty bad. If you need any help let me know!
andrew wagner
: Seems like quite a few are going this route. I
: have always been fascinated by turbos and
: their potential, but never really tried to
: build a combo with one. This time I am
: commited, and with all the info and help
: available on the web, it will become a
: reality.
: Tom
PostPosted: Sun Jul 07, 2002 5:46 pm
: I run a turbo on my slant six. You can go to
: <A HREF="http://home.earthlink.net/~mrdartgt/">h ... dartgt/</A> or
: wangermotorsports.net I do not have pic of the
: new setup on there but some of the other
: thing that I did are on there. I make costom
: turbo kits for alot of other types of cars
: to. I got a stock engine to go 14.50 @ 95
: mph, that was intercooled and at 10 lbs of
: boost. I have got a new engine built up with
: turbo cam ,head work, But I needed to get a
: bigger radiator so I am running 4 lbs until
: I get a new intercooler. The new engine ran
: 15.06 @ 90 at 4lbs. The tranny was sliping
: pretty bad. If you need any help let me
: know!
: andrew wagner
Andrew, are you still running the turbocoupe turbo? And if so does it have the .48 housing or the .63? I am going to attempt to use two of the .48 housing turbos on my /6. I am also in the process of building a fairly large intercooler for it. I pondered using the buick gn turbo, but it seems to really work better with an aftermarket downpipe. What type of custom work are you doing? Header, manifold etc?
PostPosted: Sun Jul 07, 2002 10:10 pm
Wagnermotorsports.net
I spelled it wrong!!!
Here is a pic of the header. My turbo has the .48 exhaust, and .63 compessor side. The gn turbo is a good turbo! looks like your intercooler will be nice.
andrew wagner
: Andrew, are you still running the turbocoupe
: turbo? And if so does it have the .48
: housing or the .63? I am going to attempt to
: use two of the .48 housing turbos on my /6.
: I am also in the process of building a
: fairly large intercooler for it. I pondered
: using the buick gn turbo, but it seems to
: really work better with an aftermarket
: downpipe. What type of custom work are you
: doing? Header, manifold etc?
PostPosted: Sun Jul 07, 2002 10:12 pm
PostPosted: Sun Jul 07, 2002 10:22 pm
Nice looking header Andrew. Do you build and sell these? And if so, how much?
Tom
PostPosted: Mon Jul 08, 2002 6:05 pm
yes I do! I can make any type of header you want. Its about 350 for a steel header and 450 for a stainless header. I am slowly getting things on the web site together.
andrew wagner
: Nice looking header Andrew. Do you build and
: sell these? And if so, how much?
: Tom
PostPosted: Mon Jul 08, 2002 6:57 pm
: yes I do! I can make any type of header you
: want. Its about 350 for a steel header and
: 450 for a stainless header. I am slowly
: getting things on the web site together.
: andrew wagner
What size tubing is the header you have pictured?
Tom
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 28 guests
