It is currently Sat Nov 28, 2026 12:06 am
 Post subject: Possible tranny swap
PostPosted: Wed Aug 29, 2007 7:54 pm
Somebody is parting out a 75 Duster. I haven't looked at it yet, but he says it has a 4 spd. I would like to put a 4 speed floor shift in my 63 valiant and I've read some posts about how to do this. My question is, was this transmission offered on this car as stock? If so, what parts do I need to grab besides bell housing, shifter, linkage?
I'm also getting the electronic ignition and the two barrel set up 8)
PostPosted: Wed Aug 29, 2007 8:45 pm
Yup, the overdrive 4-speed (A833OD) was offered in the A-bodies with 225 engine in '75 and '76. Get everything. Bellhousing, transmission, driveshaft, floor hump if you can cut it out of the car, shifter/linkage.
PostPosted: Fri Aug 31, 2007 8:47 am
Slant Six Dan is right . Get a big chunk of the trans hump if you can. Makes for a much cleaner look when you're done.
On my older Valiant there was a little bending to fit required (77 Aspen donor car) but it was worth it.
It's a great swap. I didn't change my rear gears, and the motor just glides on the freeway now. Of course you could take advantage of the overdrive and put some very high ratio gears back there, and maintain your current top speed.
It's not a hard swap. Go for it.
66 Valiant, 225.
84 Van, 225.
71 Maxi-Van, 318
60 Valiant wagon, 225
87 Maxi-Van, 318 4spd
PostPosted: Fri Aug 31, 2007 4:40 pm
He sold it before I got there. The intake and electronic ignition were gone too :x
If anybody knows where I can get a electronic distributor, or the super six intake and Carter carb, I would appreciate it. I think I can wait on the 4 speed for a while. I see the distributor on Ebay for around $60 plus shipping, but by the time I get all the other parts needed for the HEI conversion from RockAuto, I'll be into it $250.
Thanks
PostPosted: Fri Aug 31, 2007 5:10 pm
I believe there's a 2-bbl manifold on Ebay now.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Aug 31, 2007 7:16 pm
I have a Super Six intake and a couple of Carter BBD carbs. I have no other Super Six parts to sell though. $50 to whomever wants to visit Yacolt, Washington.
PostPosted: Fri Aug 31, 2007 10:36 pm
I might take em, PM me with your info and I will take a look sunday or monday if it works for you....you got mail
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Sun Sep 02, 2007 7:47 am
There is an A833 4 speed posted on ebay right now, just saw it. There isn't a shifter, linkage, etc. I picked up a bellhousing at Turner's Auto Wrecking in Fresno CA, they will ship to you. Then pick up linkage, clutch fork, etc. from Brewers.
Good luck,
PostPosted: Tue Sep 04, 2007 5:05 pm
Pick up a Pertronix ingition for about $100. Hooks up with 2 wires and you're done! I have them on several slants. It's a lot quicker upgrade than the '72 and later Chrysler setup.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Tue Sep 04, 2007 7:05 pm
I have the Pertronix, but I was thinking I may need a new distributor. However, Joshua helped me diagnose it as a possible Carb issue. Thanks for the help!
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], DuckDuckGo [Bot] and 5 guests
