It is currently Fri Nov 27, 2026 6:48 pm
PostPosted: Wed Sep 05, 2007 12:45 pm
Now heres the prob i called edge converters back the 1st time i was told they could get 3000rpm stall outa the mild converter which is 300 buck now he's saying i'd have to buy the 500$ one the high performance converter what should i do and know any other companies? and would this idea work to use (just an example) use like a 5000rpm stall v8 converter to get the lower stall like around 3000 on my slant six? help please
Thanks Kevin
PostPosted: Wed Sep 05, 2007 1:29 pm
http://www.raceconverters.com/
Call them and tell them what you want to do. Should be around $400.
PostPosted: Wed Sep 05, 2007 2:12 pm
I got a 10" street converter from Midwest that stalled 3000 behind a stock slant for $318 shipped to my door. That was a ferw years ago. I don't think prices have gone up too much. IIRC, Fred is the guy you want to talk to.
A converter that stalls 5000 behind a small block will still stall almost 4500 or so behind a Slant. 3000 should be a piece of cake. :lol:
PostPosted: Wed Sep 05, 2007 8:09 pm
Thanks guys ya i was thinking of the v8 converter idea but then i though hmm it'll probably be more or just as exspensive since it's got a huge stall rating not to mention if it would fit my 1964 engine and 1974 tranny.
Thanks Kevin
PostPosted: Thu Sep 06, 2007 2:01 pm
Make sure to tell them you have a small register crank or you will get a late converter that will not fit your motor.
