It is currently Wed Jun 03, 2026 2:39 am
PostPosted: Fri Sep 07, 2007 6:34 am
Howdy everybody
I recently had fuel problems in my 72 demon, possibly because of a dirty tank. I took everything apart and cleaned and blew out, etc. only to find that the fuel pump was bad- it only blew, not sucked!
Now that I'm back together with a full tank I have a drip from my sender unit gasket. I can't find anywhere that sells a new one, and Im afraid to make one from rubber that might melt in the crappy caustic gas they sell now.
Who sells the gasket? I also need a new float (my plastic one was cracked at the seam) and sock (same thing).
Thanks
Kevin
madam im adam
PostPosted: Fri Sep 07, 2007 8:28 am
Yearone has the gasket and float. I think the float was availible at ford dealer, don't have the # off hand but you should be able to search for it.
Try www.jacksautoparts.com too
PostPosted: Fri Sep 07, 2007 8:39 am
Float: Ford P/N COAZ-9202-B
Strainer "sock": GM P/N 5651 705
Gasket: Chrysler P/N 6031 475
Sender grounding clip: Chrysler P/N 2258 862
PostPosted: Fri Sep 07, 2007 9:55 am
You know Dan has that copied ready to paste at a moments notice ;)
Thats for the 5/16" strainer right?
One time I was in a rush for one and couldn't find one locally - the local auto parts stores stock ones for modern cars that are soft instead of rigid. I know the parts store guys and we opened a few boxes until we found one that fit snug over my senders tube. Its held up fine.
PostPosted: Fri Sep 07, 2007 10:42 am
Yep, that's the 5/16" strainer sock. :-)
PostPosted: Fri Sep 07, 2007 12:02 pm
special thanks to Dan for the #s- I am glad someone knows how to translate to parts counter people language :lol:
madam im adam
