It is currently Fri Jul 03, 2026 8:48 pm
PostPosted: Mon Jul 08, 2002 1:46 pm
A 6 74 Duster showed up in the local yard when I made a visit Friday. The car has front disks and the 4 1/2" bolt circle wheels.
My question is will the brakes and axles from this 7 1/4 swap directly onto the 68 7 1/4 housing under my Barracuda? I heard that some where along during the production of these axles some parts changed and I do not recall if they are interchangeable. I do not want to swap the whole axle because my car has 3.23's, the Duster is 2.7 and I do not want to get involved in swapping gears. I will eventualy get an 8 1/4 with sure grip under the car.
Hot-Rod 6
dave.clement@motorola.com
PostPosted: Mon Jul 08, 2002 3:07 pm
: A 6 74 Duster showed up in the local yard when
: I made a visit Friday. The car has front
: disks and the 4 1/2" bolt circle
: wheels.
: My question is will the brakes and axles from
: this 7 1/4 swap directly onto the 68 7 1/4
: housing under my Barracuda? I heard that
: some where along during the production of
: these axles some parts changed and I do not
: recall if they are interchangeable. I do not
: want to swap the whole axle because my car
: has 3.23's, the Duster is 2.7 and I do not
: want to get involved in swapping gears. I
: will eventualy get an 8 1/4 with sure grip
: under the car.
Dave,
Try a search for 7 1/4 or similar. I know Doug has covered this before, as far as what year axle shafts interchange. I seem to remember that the later big-bolt axles would not bolt into the earlier housings, unfortunately. I believe you can put your 3.23s into the later housing, but not the axle shafts into the earlier housing. Hope this helps,
PostPosted: Fri Nov 01, 2019 3:09 pm
Car Model: 1962 plymouth valiant
DROP IN A 8-1/4 WITH 4.5" PATTERN AND GET MORE LIFE
