It is currently Mon Jun 15, 2026 9:34 am
 Post subject: Carter BBD Model 4421
PostPosted: Sun Sep 09, 2007 1:18 pm
I just purchased a 1968 225 SL6. The seller included a Carter BBD Model 4421 2-bbl carb (I identified it by some photos on the internet) with an aluminum manifold.
Does anyone know the specs on this carb and where I might find a detailed drawing/exploded view of it?
Thanks TJ
1987 Dodge D150 225 Slant-6 w/4-spd (A833OD)
PostPosted: Sun Sep 09, 2007 1:26 pm
Carb was originally intended for a '68 318 passenger car application with automatic trans. You'll have some adaptation work to make the automatic choke work on a slant-6. Exploded view comes with a quality carb kit. You can also download the BBD manual I put together from Carter & Chrysler sources last month.
PostPosted: Sun Sep 09, 2007 3:05 pm
Thanks, Dan. I appreciate the input.
PostPosted: Sun Sep 09, 2007 6:31 pm
Hi Dan.
You mentioned that I would need to do some modifications to get Carter carb to work with the slant-6. I'm connecting to a A833 OD 4-speed manual. Will this make the mod easier or more difficult.
In general, can you describe the modification(s).
TJ
PostPosted: Sun Sep 09, 2007 6:46 pm
The choke lever is a V8 style that won't mate up properly with a slant-6 2bbl choke pushrod, and the '68 carb was made before the choke levers were held on with a screw, enabling a swap from the V8 to the \6 choke lever (the earlier carbs like yours have the choke lever staked/peened onto the choke shaft). I've made the V8 choke levers work by creating a new choke pushrod for use with the factory-type choke thermostat. It'd be easier to start with a #1232 Electric choke kit, because those kits are adjustable while the factory chokes are not.
The only other mod that would need considering would be if your '68 carb is a Clean Air Package unit with a hole in each throttle plate. Check and see.
Other than that, there's no mod needed. Everything'll hook up. Use the '66-'69 273/318 air cleaner and the shorter accelerator cable.
PostPosted: Sun Sep 09, 2007 7:35 pm
Not to hijack the thread, but how do I view that Carb manual PDF on a mac?
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Sun Sep 09, 2007 8:16 pm
Same way you view any other PDF on a Mac. With Adobe reader or OSX Preview.
 Post subject: Thanks again!
PostPosted: Sun Sep 09, 2007 9:17 pm
Thanks, Dan. I'm sure I'll have a hundred more questions for you and others as I move forward on my project.
PostPosted: Mon Sep 10, 2007 7:26 am
Glad to help! :-)
Users browsing this forum: Amazon [Bot] and 1 guest
