It is currently Tue May 19, 2026 5:12 am
 Post subject: possible tranny problems
PostPosted: Sat Sep 01, 2007 8:51 pm
Greetings from a newbie. got a problem which occurred while shifting from n to d. car stalled from being cold. once started it self accelerated just as i was going into drive. something cluinked and now my car bucks when trying to go from 1st to 2nd, changed the rear end and problem still exists. have a couple of ideas ie ujoint but the ujoint passed the diagnostic check. kinda thinking flywheel or some trany adjustment. help! we haven't been able to take advantage of the decrease in gas prices :D
fenomenalkatt!!!
'67 Dart "Sandy"
225/904
PostPosted: Tue Sep 04, 2007 5:11 pm
Can you clarify the problem a bit? I'm not sure I understand it. Does reverse work? Does it shift into 1, 2 & D?
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Sun Sep 09, 2007 9:51 am
I believe the term is that i slammed the tranny. It doesn't 'upshift' from 1st to 2nd so i don't know about 3rd. 1st and reverse, however are fine. I found an extensive article by Tom Hand/allpar re the torqueflite tranny both 727 and 904. think i found the link while browsing this site. So i believe it's possible that i broke the kickdown band. anyway i took off the pan and sure enough there was matter abounding so i had sandy towed to a tranny shop. she'll be undergoing a physical on monday morning and i will update. for now i'm stuck with an extra rear axle 71/4 that needs a new home 8) thanks for the reply!!!
fenomenalkatt!!!
'67 Dart "Sandy"
225/904
PostPosted: Sun Sep 09, 2007 2:46 pm
Consulting my hydraulic circuit drawings, it appears that the kickdown band is not being applied.
PostPosted: Mon Sep 10, 2007 8:21 am
I think its the kickdown band as well. i'll post an update in an hour or two as soon as the shop finishes its exam
fenomenalkatt!!!
'67 Dart "Sandy"
225/904
 Post subject: Update
PostPosted: Mon Sep 10, 2007 1:28 pm
Well, well, well according to Dr Jack @ Wholesale Transmissions in Berkeley, I have a wiped out, unrebuildable case my Sprague assembly blew up due to the kickdown band snapping and sending pieces flying, which means my torque converter is full of metal. So Sandy should be rolling in a couple of days!!!
fenomenalkatt!!!
'67 Dart "Sandy"
225/904
