It is currently Thu Jun 18, 2026 2:19 am
PostPosted: Sun Sep 09, 2007 6:35 am
I pulled #1 and #3 plugs to look at them. Last time I pulled them they were fresh. Back then they gave the indication I was running dangerously lean.
I have since
#1. drilled the jets out to the next biggest drill bit size.
#2. changed to the proper PCV VS whatever fit the grommit :roll:
The PCV change added some bottom end torque.
Anyways it still pings badly.
Looking at the plugs with the ground strap int the center back the insulator has a dark brown half way. Then the other half is is a nice tan.
I didn't index the plugs if that's what you are thinking.
I have a set of 1 or 2 range colder plugs I will be installing after a carb swap. My BBD right now has a shaft leak :roll:
I am polishing and porting a '65 273(?) BBD.
PostPosted: Sun Sep 09, 2007 7:32 am
I always thought that bown/tan color was what you were looking to see. I think the brown is caused by additives to the fuel.
Sam
 Post subject: Brown/Green...
PostPosted: Sun Sep 09, 2007 7:48 am
I have also seen that current gasoline additives give the plug a green/brown appearance depending on your gas station of choice.
PostPosted: Sun Sep 09, 2007 10:16 am
Sam
Well I guess my question is why brown on 1/2 of the insulator? We are talking split right down the middle.
Half tan/ half brown. I've never seen a plug like that.
PostPosted: Sun Sep 09, 2007 7:21 pm
Sam
Half of it is washing out under load. No big deal.
PostPosted: Mon Sep 10, 2007 3:38 am
Washing out? Like incomplete combustion?
PostPosted: Mon Sep 10, 2007 8:19 am
Yes....... But you can help it through tuning. Looking for tan or brown color on a plug to indicate fuel mix is not really the way to guess fuel mixer. My guess is your pig rich & maybe even a weak ignition system to boot.
Wet flow of the /6 head cant be to good. I can only guess what some of these heads work like after porting.
Jess
PostPosted: Mon Sep 10, 2007 4:36 pm
What's wrong with my breaker points? :lol:
I wish I could post pics here.
PostPosted: Mon Sep 10, 2007 5:04 pm
You have to upload your pictures to a site like photobucket and link to them here with the Img tag.
My car still has points. Got over 21 MPG at the last fill-up.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
