It is currently Tue Jun 09, 2026 4:38 am
 Post subject: crank scraper
PostPosted: Mon Sep 10, 2007 8:52 am
found this on e-bay and it looks like they make them to order if anyone is interested
Item number: 200147863319
or crank-scrapers.com
I don't know of this company nor have I ever done any transaction with this company but they have what everyone wants so I figured id let everyone know
PostPosted: Mon Sep 10, 2007 3:42 pm
Online
There are a few people on this forum, that have gotten scrapers from Kevin. A few of us lent him engines to use for a pattern. He does come to this site. Nice people.
PostPosted: Mon Sep 10, 2007 4:16 pm
he is a nice guy- I am waiting for him to get back to me on a patent idea. hopefully he'll see this post and remember it, its been awhile.
PostPosted: Mon Sep 10, 2007 6:34 pm
I have one of Kevin's scrapers in my good motor. Mike Jeffrey also does scrapers. :D
PostPosted: Tue Sep 11, 2007 12:21 pm
I thought mike just did trays? I was talking to kevin about a tray, haven't heard from him.......... :? hope he's just busy.
PostPosted: Tue Sep 11, 2007 1:54 pm
Mike does lots of things. :lol:
PostPosted: Wed Sep 12, 2007 5:31 am
Ah.
do you have any pictures of either unit? I got burned on a tray before.......
PostPosted: Wed Sep 12, 2007 8:31 am
if you copy and past the ebay item # in my first post im pritty sure it will still let you look at it, they had some really good pics installed and out of the engine
PostPosted: Wed Sep 12, 2007 8:34 am
also I just noticed in the pics how would you seal the oil pan with this installed also how would you line it up seeing how it bolts up whare the pan bolt's on
PostPosted: Wed Sep 12, 2007 11:49 am
I have a single-sided scraper in my 64 motor from Kevin. Just ordered a 2-sided for the new Project V motor.
PostPosted: Wed Sep 12, 2007 3:44 pm
The gaps you fill with silicone sealer, the end seals will still seal fine. I siliconed mine to the block and then used a pan gasket only on the pan side. I bolted the scraper/silicone down overnight, and then install the pan as usual. :D
sick6-Mike's tray is a copy of the old Direct Connection tray. Both Mike's scraper and tray, and Kevin's scraper will require some clearancing to install. It is not hard, just a little time consuming. :D
PostPosted: Wed Sep 12, 2007 6:21 pm
clearancing, as in grinding a bit off of the tray?
PostPosted: Wed Sep 12, 2007 8:19 pm
Yep, they fit some pans better than others. I didn't have to grind much to get it into a '76 A-body pan, but had to do quite a bit to get it into a '66 pan.
PostPosted: Thu Sep 13, 2007 6:23 am
would their be any benefit to using a tray along with a scraper or would that just be overkill
PostPosted: Thu Sep 13, 2007 2:24 pm
Unless you plan on turning a lot of RPM regularly, there isn't a whole lot of benefit to either. :shock:
