It is currently Fri Nov 20, 2026 10:56 am
PostPosted: Thu Sep 13, 2007 1:11 pm
Hi !! Replacing my motor mounts on 74 Satellite w/ slant six and can't determine which ways the mounts go in. The bolt hole in the new mounts are not centered- they are offset in one direction by 1/2". There is also an arrow cast into the mounting rubber. My old mounts are dust, so there is no way to determine which way they go in from looking at the old ones.. Thanks Guys.. dave
PostPosted: Thu Sep 13, 2007 2:26 pm
Just a guess, but the arrow probably points up?
If the bolt hole is offset, I would think you would want the thicker part of the insulator to be to the bottom. :D
PostPosted: Thu Sep 13, 2007 11:58 pm
TTT hopfully someone on here knows... thanks-dave
Users browsing this forum: Bing [Bot] and 10 guests
