It is currently Wed Nov 18, 2026 1:12 am
 Post subject: numbers matching
PostPosted: Mon Sep 17, 2007 6:31 am
How can I find out if my slant is the original to my Satellite?
PostPosted: Mon Sep 17, 2007 7:00 am
Part of the VIN number should be stamped on a pad under the #5&6 spark plugs. It will be a pad just like the one the CI number is stamped on at the front of the block.
 Post subject: between the 5th and 6th
PostPosted: Mon Sep 17, 2007 1:05 pm
Thank you for that info, that helps out alot
 Post subject: humm
PostPosted: Mon Sep 17, 2007 1:10 pm
I looked but did not see a number or any type of marking. The only numbers are on the left side ( intake side).
PostPosted: Mon Sep 17, 2007 3:56 pm
The pad is actually a flat on top of the block that extends from under the head, facing straight up. You will probably have to scrape the sludge off of it to see it. The numbers are stamped, not cast, and aren't real big. :D
 Post subject: Hummm
PostPosted: Tue Sep 18, 2007 5:32 am
I believe I have found it. Its position makes it really hard to see. I am going to try to use a camera to get a picture since I can not get a strait line of sight.
 Post subject: Re: Hummm
PostPosted: Tue Sep 18, 2007 1:25 pm
Yes, both the serial pad and the CI pad can be tough to find. :D
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 3 guests
