It is currently Mon Nov 16, 2026 11:21 pm
 Post subject: Bigger valve
PostPosted: Fri Sep 21, 2007 9:43 pm
I was wondering if there would be any advantage to installing a larger exhaust valve, leaving the intake the same size. My brother inlaw and I were shooting the bull about bigger valves and he mentioned he was going to try this on a non mopar engine. I was curious.
Excuse me, does this smell like chloroform to you?
PostPosted: Sat Sep 22, 2007 1:24 am
Car Model: 1964 Dart GT
The slants head was designed for the 170cid. They never updated it for the 225 or 198. A normally aspirated slant would benefit from both valves being enlarged.
A turbo motor would probably do better with a larger exhaust/intake size ratio.
PostPosted: Sat Sep 22, 2007 1:02 pm
Most engine builders like to keep valve size within a certain percentage, along with intake/exhaust flow. The number we shot for at the race car shop was 75% IIRC. A motor with too much exhaust flow gives up some power. :D
PostPosted: Sat Sep 22, 2007 5:27 pm
Slant is already exhaust favored, so bigger intake and stock exh would probably be better.
PostPosted: Sat Sep 22, 2007 7:06 pm
Thanks, guys.
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
