It is currently Tue Jun 16, 2026 5:31 pm
 Post subject: aluminum slant 6
PostPosted: Wed Sep 26, 2007 9:38 pm
I was reading an article " Aluminum Slant Six Engine Overview" and had a couple of questions about the numbering on the engine block. My block has many more numbers on it than in the article. I would like to know what they mean. Thanks
Last edited by aluminum6 guy on Mon Nov 26, 2007 10:34 am, edited 1 time in total.
PostPosted: Wed Sep 26, 2007 9:44 pm
I don't know anything about the numbers, but wonder if your engine runs. Is it in a car? You should feel good about having it at all, and I hope you get it going if it does not run now.
Sam
PostPosted: Thu Sep 27, 2007 10:34 am
Die cast mold numbers and run dates.
PostPosted: Thu Sep 27, 2007 1:08 pm
What exact info do these numbers represent?
PostPosted: Thu Sep 27, 2007 1:13 pm
Sam
It is a block that was never in a car. It was assembled, run in the Chrysler testing lab, torn down for inspection, and put away. It has been in indoor storage ever since. I am interested in decoding these numbers. Awsome car!!!
PostPosted: Thu Sep 27, 2007 5:06 pm
Wow!
A engine never in a car. That's a rare find. :)
Cheers, Wizard
PostPosted: Thu Sep 27, 2007 6:35 pm
Thanks man! I hope you find a nice car for your aluminum slant. Doctor Dodge is most likely the guy to help you figure out how to build it.
Sam
PostPosted: Thu Sep 27, 2007 9:34 pm
Wow!
Cheers, Wizard
Thanks. I looked long and hard to find it. I have had it in my garage for about 22 years. Now I am trying to find someone who can decode the numbers.
PostPosted: Thu Sep 27, 2007 9:40 pm
Sam
F ortunatly, I have been building racing engines for over 35 years. I am just curious on how to decode the numbers.
PostPosted: Thu Sep 27, 2007 10:36 pm
Cool, how many were aluminum slants? Iron ones?
PostPosted: Fri Sep 28, 2007 4:56 am
In that case, Doctor Dodge is likely still the go to guy to get info on campatability of parts, gaskets, heads, cams etc. He is part of a racing community that has traveled this road more than a few times, and their advice is "priceless" as the Master CArd ad says.
Sam
PostPosted: Fri Sep 28, 2007 8:17 am
Is there a stamped number on the passenger side bell housing flange>
Are the other number you discribed casted-in or stamped-in?
PostPosted: Fri Sep 28, 2007 1:47 pm
Both numberings are stamped in.
PostPosted: Fri Sep 28, 2007 2:22 pm
Are there any stamped numbers on the main ID Pad?
PostPosted: Sat Sep 29, 2007 11:35 am
The only number on this block at that location is 7/16. Thanks Doc
