It is currently Sun Nov 15, 2026 11:18 pm
PostPosted: Thu Sep 27, 2007 9:51 am
Car Model: Road Runner
I'm sure SSDan will be able to hadle this one with a flick of his pinkey finger, but I can't seem to find the answer an neither can my parts stores. I have a Carter 2425 that i need to rebuild and the parts listing jumps from 2424 to 2428. Can't find any other cross refrence. Is there a "blanket" kit that will cover my carb, or a specific kit. It looks like I'll have to go through Napa for this one, maybe carquest. Thanks
PostPosted: Thu Sep 27, 2007 3:00 pm
Where are you finding the 2425 number? If it's cast into the carburetor itself, it is not the carburetor number. The carb number was originally on a triangular aluminum tag secured under one of the bowl screws. They frequently get left off over the years.
PostPosted: Thu Sep 27, 2007 5:42 pm
ooooo...is the number located somewhere else on the body?
PostPosted: Thu Sep 27, 2007 5:51 pm
Now that you mention it, my Carter also has that same casting, probably the same number. I can't read the numbers, but they are cast into the passenger side of the air horn.
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Fri Sep 28, 2007 4:50 am
There aren't any numbers stamped or cast anywhere on the carb itself that will positively ID it. If the tag's gone, the number's gone. It'd be nice if Carter had stamped their numbers into the carb, as Holley and Stromberg did, but they didn't request my vote before deciding on the separate-tag approach.
A few clear, sharp photos of your carb from multiple angles ought to provide enough info to point you to the right kit.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
