It is currently Mon Nov 16, 2026 4:42 pm
 Post subject: Elgin oil pumps - Help
PostPosted: Fri Sep 28, 2007 4:39 am
Hi guys,
First up - are these kits OK?
Then the bolts they refer to - is it the ones on the cover?
The couple I have seen over here is all 5 bolt - on cover types............
EK-66A w/Dist Dr Gear .650 Rotor Thickness 6 Bolt Pump Mounting
EK-66CA w/Dist Dr Gear .826 Rotor Thickness 5 Bolt Pump Mounting
PostPosted: Fri Sep 28, 2007 6:00 am
Using a search engine to try to try to find the above mentioned kits, I found this: A chinese manufacturer of oil pumps. Check out the oil pump in the bottom right corner. I wonder who they make this for? Melling is made in the U.S.A. , right?
http://www.pingchai.com/web/eproductt.a ... &newstype=
PostPosted: Fri Sep 28, 2007 6:47 am
Given that you found this Ping Chai outfit in China, I would say it is a better than good guess that this is what you get no matter whose name is on the box these days. :-(
PostPosted: Fri Sep 28, 2007 8:28 am
The bolts are the pump hold-down bolts, not the cover bolts.
Impeller size is the most important piece of information you need when ordering a oil pump rebuild kit.
In general, the 6 bolt pump is the .650 impeller and the "5 bolt" are the thicker .826 impeller.
Over the years I have seen some exceptions to the number of bolt holes verse impeller size.
PostPosted: Fri Sep 28, 2007 2:02 pm
Oh boy!!!!
If you go to that site, and scroll the pictures, the lower right hand one looks like the slant six. However, click on the picture, and it gives a part number PC 1044, then M66C which is the melling part number for the slant oil pump. Then lists the application as being FORD. This does not give me confidence in their products.
PostPosted: Sat Sep 29, 2007 10:33 pm
Autozone lists 3 oil pumps for the slant - M-66HV ($57.99) , M-66C ($39.99), and the OM-66-C for the "What the #$&* is going on here" price of $105.99. The first two pumps are listed as Melling units and the last one is listed as Hi Tech. Does anybody know what's so special about the Hi Tech pump?
PostPosted: Sun Sep 30, 2007 1:56 pm
I heard from our one local shop that Melling and Elgin was sort of involved at
one stage
Is there anyway to id the pump without pulling it from the block? :?: :?:
PostPosted: Sun Sep 30, 2007 2:13 pm
Oh yes the url
sorry :oops:
http://www.elginind.com/engineproducts.html#
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
