It is currently Thu May 21, 2026 10:04 pm
PostPosted: Fri Sep 28, 2007 6:02 pm
I looked at Hurst and B&M, but didn't really see anything that'd look like it would work with a bench seat installed. Now that I've made up my mind to keep a 3-spd auto and save up for a Gear Vendors overdrive, I want to lose the column shift and install a floor shifter. No real reason behind it, except it's just a personal preference.
does anyone here use a floor shifter with an automatic and the bench seat still installed in their A body?
 Post subject: I use a promatic 2
PostPosted: Fri Sep 28, 2007 7:00 pm
I have a bench seat and use the promatic 2...its a ratchet shifter so the sitck basically is in the same place except for parl amd reverse. Fits in a tight space and now that I am used to ratcheting, I love the shifter. I just didn't need a quarter stick..
rock
'64d100
PostPosted: Fri Sep 28, 2007 7:26 pm
I have a Quarterstick in my '66 with a bench, a buddy has the equivalent B&M in his '70 Dart with a bench. Both work fine.
I ran the ProMatic 2 in my Duster with a bench and buckets at different times. It worked well too.
PostPosted: Sat Sep 29, 2007 1:48 pm
Question for both you guys: how are the shifters as far as ease of reaching?
Since I plan ton obtain a Gear Vendors unit, I'd like a shifter I can install a button on to control it with, plus I'm planning on a fully manual valve body when I figure out if keeping the 904 or going with a 727 will be my best option, so would a ratcheting shifter work for that?
PostPosted: Sat Sep 29, 2007 7:14 pm
Jopapa,
Please expand a tad on what "control it" means. For instance the ProMatic uses a cable ....are you wanting to somehow control the shift electrically and replace the cable? Or do you just want to mount a button on the shifter handle and have the button control something like the neutral safety switch...or ?
Thanks
rock
'64d100
PostPosted: Sat Sep 29, 2007 9:44 pm
My personal feeling is that a ratchet shifter is a pain in the ass with a full manual valve body. :P
PostPosted: Sun Sep 30, 2007 10:24 am
Jopapa,
Thanks
rock
'64d100
Since the Gear Vendors unit is controlled by a pushbutton, I wanted something on the shifter that I could hit to control that. Now that you mention it though, a NSS and Reverse light switch I wouldn't even think are necessary, because aren't they installed on the transmission itself, with the 904 and 727?
Slantzilla, that's pretty much what I was wondering. So methinks I'm going to want a gated shifter in this case...
PostPosted: Sun Sep 30, 2007 11:23 am
If the GV unit only requires a momentary contact, you can get shifter handles with a PB in them.
My QS is the pistol grip style that has a button on the top of the handle. :D
If you really, really want to have fun with a RMVB, get ahold of an old set of Hurst Lightning Rods. I have a 3 stick set that I had in my Valiant for a couple years. :lol: :lol: :lol:
PostPosted: Sun Sep 30, 2007 1:52 pm
RMVB = Reverse Manual Valve Body?
I think I'd be better off with a forward valve body, just in case I let anyone else ever drive my car...
 Post subject: Hi jopapa,
PostPosted: Sun Sep 30, 2007 3:00 pm
Yes,
THe neutral safety swiitch and reverse light switch is on the tranny...unless like many where that switch doesn't work. The Promatic has the switch built into the shifter itself. I don't remember if the 1/4sitck does...
rock
'64d100
PostPosted: Mon Oct 01, 2007 4:31 am
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
Easy, don't let anyone drive your car!
Richard (aka Fingers)
Users browsing this forum: No registered users and 16 guests
