It is currently Wed Dec 24, 2025 2:34 pm
 Post subject: loose wheel studs
PostPosted: Mon Oct 01, 2007 8:41 pm
On this 66 Dart with 10" brakes I just traded a lawnmower for, all of the front wheel studs are loose in the brake drums. Looks like the drums were replaced some time ago (they have dirt and rust) and they didn't use new studs to press in, though that doesn't explain why the left side studs are all RH thread. Is this going to cause a problem, or can I wait a while to fix this? The brakes seem to work OK. The wheel isn't held centered by the wheel stud locations as much as it is by the accurate fit of the center hole over the hub, is it?
1964 Dart 225 1966 Valiant 225
1966 Dart 273 1966 Barracuda 273
1969 Dart 225
'64-170 engine '66-170 engine
(two) 198 crank/rod sets in custom-fitted wooden boxes
wooden motor scooter with hybrid-electric drive
PostPosted: Tue Oct 02, 2007 5:46 am
If the studs are just loose in the drum, and tight in the hub, you will be OK.
PostPosted: Tue Oct 02, 2007 6:27 am
I've had 10" drums on my Valiant for a while with the drums loose. It has screw-in studs, so there is no swedge anyway. :lol:
