It is currently Tue Nov 17, 2026 7:15 am
PostPosted: Tue Oct 02, 2007 3:08 pm
I put in a griffen radiator into my 63 valiant to make room put an electric fan in front, custom made my lower radiator hose but now my belt hits the lower hose. I can move my belt to the front grove on the crank pully and build out the water pump pully, But, How can I move my alternator out to match can I buy another pulley to take it out another 3/4 inch please help??? :?
PostPosted: Tue Oct 02, 2007 3:51 pm
Some Mopar alterntors have two pulleys. maybe they all do, I don;t know. Is yours one or two? If only one, then maybe you can get the extra you need with the dual pulley unit. I would think the dual pulley one is for the AC set up.
Sam
PostPosted: Tue Oct 02, 2007 4:45 pm
V-8 A/C alternators have the 2 groove pulley. :D
PostPosted: Tue Oct 02, 2007 5:46 pm
The "high output" alternators have 2 grooves all 59 amps worth.
 Post subject: I had the same problem
PostPosted: Wed Oct 03, 2007 6:09 am
I have a 72 Satellite, Yes I Know its a B-body. At one time some one replaced the original slant for a re manufactured slant. Shortly after buying the car I noticed that my belt was hitting the hose when revved up.
I tried tightening the belt to no avail. I bought a NOS replacement hose that was shaped slightly different then the one that was on it. This and careful hose placement solved my problem
 Post subject: Thanks for the tip
PostPosted: Wed Oct 03, 2007 7:10 pm
I went to the junk yard bought a dual pulley brought ot home put it on lines up perfectly with the outside notch.
THANKS FOR YOUR ADVICE :D :D :D :D :D :)
