It is currently Wed Nov 18, 2026 4:34 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
 Post subject: what gives?
PostPosted: Tue Oct 02, 2007 5:26 pm
What gives out first under boost? What kind of hp did you get?
PostPosted: Tue Oct 02, 2007 6:05 pm
Stock 80k motor has not broke yet. 259rwhp and 345rwtq. I run it rich and have it intercooled.
PostPosted: Tue Oct 02, 2007 7:31 pm
I think the Drakes went a little higher than that on boost. They killed a few head gaskets and pistons on the way though.
There used to be another young guy (Andrew Wagner?) on here that was doing some turbo stuff. He knocked out rod bearings a couple times from detonation.
Turbo is just like a supercharger or nitrous. When the tune-up is right, it's all good. When it's wrong, it's bad wrong. :shock:
 Post subject: we will see
PostPosted: Tue Oct 02, 2007 7:57 pm
We will see pretty soon. I am glad to know some of the numbers. We have a factory 80k engine and one that has studs ported head and fordged pistons. We are going to see what thefactory engine will do. The car is set up right with good suspension and gears,tranny with brake.
PostPosted: Wed Oct 03, 2007 3:54 am
Biggest problem, I had was keeping out of detonation. Would break pistons, and blow head gaskets. Keep in mind, I did mine in the late '70's, when there was no such thing as a "boost timing master", and not much turbo info available. This was a street driver, and I needed advance in the distributer, for fuel milage, but needed to retard timing when boosted. I was using mechanical means, and it was trial and error (more error).
 Post subject: locked
PostPosted: Fri Oct 05, 2007 8:52 pm
I always lock the distributor down and let the ignition box take care of it.
