It is currently Tue Nov 17, 2026 8:42 am
 Post subject: 71 engine into a 66
PostPosted: Wed Oct 03, 2007 1:24 pm
Is there anything other than the carb linkage that might cause me a headache? Will the 66 auto trans bolt up?
John
66 Barracuda 225 auto
PostPosted: Wed Oct 03, 2007 1:52 pm
If you intend to use the 66 trans you will need a bushing on the back of the crankshaft.
I am doing the same thing right now and I am using the old manifold set and carb, so I can use all the same throttle linkages.
There is a resource listed in Frank Adkins Chrysler Performance book for the crank bushing. If you need the info, let me know and I will look it up for you.
Chris
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Wed Oct 03, 2007 1:53 pm
Oh yeah, the 66 flex plate won't work on the late model crank either. You'll have to get a post 68 flex plate.
I am dealing with EXACTLY the same thing right now.
C
PostPosted: Wed Oct 03, 2007 2:15 pm
The oil pan and pick-up tube fron the 66 engine needs to be used on the 71 motor.
PostPosted: Wed Oct 03, 2007 7:33 pm
Thanks everyone,
I did a quick search and found a post about tflitepatty selling the bushings, so I sent an email. I hope the engine will come with the flex plate, so all else I have to do is find an oil pan gasket, and get the deal done with the engine. The fella I'm dealing with seems a little wishy-washy.
Once again, I appreciate the advice.
John
PostPosted: Wed Oct 03, 2007 7:51 pm
Dang I need the oil pickup too?! Ugh. One of the guys on bigblockdart hipped me to the oil pan thing. (sorry I forgot that freefish) so I pulled the 66 pan last night.
guess I'll be swappin' the tube tomorrow night:)
Thanks Doc!!
Chris E.
PostPosted: Thu Oct 04, 2007 8:50 am
One more thing, if I get the trans with it, will it match up to the driveshaft? drive train is coming from a 71 duster. My barracuda is a 66.
Thanks again...
PostPosted: Thu Oct 04, 2007 9:25 am
Thanks again...
Yes, using the 71 trans with the engine is a good way to go for any 66 and up A-Body application.
Users browsing this forum: Amazon [Bot] and 5 guests
