It is currently Sat Oct 24, 2026 7:27 pm
PostPosted: Sun Jul 21, 2002 6:46 am
Everyone knows that the big drawback with the aluminium slant is its inherent weakness, and its incompatability with high compression or supercharging.
My question is: since aluminum is supposed to be easy to weld, wouldn't it be possible to weld some sort of bracing for the barrels, or fit thicker iron sleeves to the cylinder bores along with smaller pistons? Or is that asking for disaster...
Red Rocket
glendavidshort@caribenet.com
PostPosted: Sun Jul 21, 2002 9:26 am
: Everyone knows that the big drawback with the
: aluminium slant is its inherent weakness,
: and its incompatability with high
: compression or supercharging.
: My question is: since aluminum is supposed to
: be easy to weld, wouldn't it be possible to
: weld some sort of bracing for the barrels,
: or fit thicker iron sleeves to the cylinder
: bores along with smaller pistons? Or is that
: asking for disaster...
A friend of mine, Jeff C. welded 4 or 5 pieces of aluminum keystock around the top of the cylinders, but he has yet to fire it up. He did that about 10 yrs ago, and I couldn't even guess when he will install the engine, let alone light it off.
fglmopar@aol.com
PostPosted: Sun Jul 21, 2002 11:58 am
: A friend of mine, Jeff C. welded 4 or 5 pieces
: of aluminum keystock around the top of the
: cylinders, but he has yet to fire it up. He
: did that about 10 yrs ago, and I couldn't
: even guess when he will install the engine,
: let alone light it off.
doug sis it. But I won't tell you teh results, I will simply say this (and I think doug might agree with this theory in general)
Try it and tell us what happened.
inglishboy@yahoo.com
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 9 guests
