It is currently Tue May 19, 2026 7:07 am
PostPosted: Wed Oct 03, 2007 1:26 pm
I just finished changing the gears in my rear end from 3.23s to 3.55s and I want to make my speedo accurate once again. Do I have to buy a new speedo gear for the tranny? I was told that I may be able to make adjustments within the tranny to accomodate the rear end ratio change...I'm not sure it thats true or not. If a new speedo gear is required, where can I get the correct one and how do I know what I need (# of teeth)? Any help here would be greatly appreciated!
1965 Valiant 200
170 C.I
PostPosted: Wed Oct 03, 2007 1:38 pm
You will need to change the gear that goes on the trans end of the speedo cable. First thing what year is the trans? Then will need to know the size of the tire, to go along with the gear ratio.
PostPosted: Wed Oct 03, 2007 2:17 pm
My transmission is a 1965 Chysler 904 3-speed and my tire size is 25.4 inches.
1965 Valiant 200
170 C.I
PostPosted: Wed Oct 03, 2007 2:58 pm
Ooofff, that makes it harder. The 65 and older speedo gears are harder to find. No source of NOS, just used. Will have to look up the color/number of teeth, you need. Then someone may have one laying around.
PostPosted: Wed Oct 03, 2007 3:38 pm
Hello,
That ole Chaarlie knows his s...tuff. I think I have your gear in my stash and NO forseeable need for it. PM me need to know your tranny and gear ratios in 1,2, 3 Gears are about $15, BTW
rock
'64 d100
PostPosted: Wed Oct 03, 2007 4:09 pm
In order to figure out which gear you need, we need not only the rear gear ratio but also the tire size you're running.
PostPosted: Thu Oct 04, 2007 7:22 pm
Alrighty then.....I have 3:55 gears in my rear end and I have 25.4 inch tall tires. What speedo gear to I need? Where might I be able to pick one up? Any help would be greatly appreciated!
1965 Valiant 200
170 C.I
PostPosted: Thu Oct 04, 2007 7:39 pm
Arrgh...this'll be easier to figure out by far if you'll please state your actual tire size rather than its diameter.
 Post subject: 904
PostPosted: Fri Oct 05, 2007 5:52 am
Sorry Dan....I misunderstood you! My actual tire size is 205/70/R14.
1965 Valiant 200
170 C.I
PostPosted: Fri Oct 05, 2007 5:59 am
Gotchya. You need a 19-tooth, dark blue speedo drive pinion.
 Post subject: 904
PostPosted: Fri Oct 05, 2007 1:48 pm
Thanks SlantsixDan!
1965 Valiant 200
170 C.I
 Post subject: dk blue gear
PostPosted: Fri Oct 05, 2007 6:55 pm
I have a blue one but how do you count the teeth? I get 21-- but on the moparts info it should be grey for 21 --- blue = 19-- and this piece is definately not grey., Lawrence
 Post subject: Re: dk blue gear
PostPosted: Sat Oct 06, 2007 5:40 am
What is the dia of the gear? The 65 gear should be about 1 inch in dia, the 66 up gear is about 1 1/2 inch maybe a little larger. You might be looking at the late model gear. The color/tooth count may be different, between the years (eary/late).
 Post subject: gear size
PostPosted: Sat Oct 06, 2007 6:50 am
this is correct for push button style-------- my 62 fsm lists
700-14 2.76--ratio- 17 orange
3.23 20 lt blue
650-14 2.93 16 lt purple
3.31 18 dk purple
3.58 20 green
650-13 2.93 17 natural
3.23 19 dk blue
3.55 20 green
All of these are with a 7 tooth output shaft
64 fsm
650-13 2.93 17 orange
3.23 19 dk blue
3.55 20 green
700-14 2.76 16 brown
2.93 16 brown
3.23 18 dk purple
3.31 18 dk purple
7 tooth output(6cyl cars) above list
700-14 2.76 17 orange
2.93 18 dk purple
3.23 20 green
3.55 20 green
8 tooth output(8cyl cars)
How do you correctly count the teeth-- I used the flat edge starting with a molded casting # & counted all of the teeth for my # 21-- the unit is definately blue in color-- but I do not match the above listings, Lawrence
PostPosted: Sat Oct 06, 2007 7:19 am
It's been a while since I've looked, but I thought there was a tooth count molded in to the body of the gear. Maybe I'm thinking of something else.
To count the teeth on other gears and such, I just mark one and count it as number 1 then continue around the gear until I get back to the marked one. Just be sure to not count the first one twice.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
