It is currently Sun May 31, 2026 11:23 am
 Post subject: Rotor not turning
PostPosted: Fri Oct 12, 2007 7:33 pm
Ok, all Help....
I've searched the data base and found if the rotor is not turning then its the timing chain or a gear??
the 71 :evil: 225 slant six was running rough. Followed the advice of many and switched to Pertronix. She ran great for a day and then I took a corner and she died. I got her started and nursed her home now she won't start just turns over.
I pulled the cap and the rotor doesn't move. A friend of mine told me to take off the valve cover and see if the valves move. If they do then its the gear on the distributer assembly and not the timing chain. :evil:
Any info is greatly I mean greatly appreciated.
Thanks
Jeff
PostPosted: Fri Oct 12, 2007 7:41 pm
I would pull-out the distributor first. (fewer bolts to remove)
Inspect the distributor's plastic drive gear, then go from there.
PostPosted: Fri Oct 12, 2007 7:44 pm
Thanks for the quick reply DD,
I understand you turn this to the twelve oclock position and then it pulls right out?? I could quit being lazy and go read the book.
Thanks for the help
If you always do what you've always done, you always get what you always got.
PostPosted: Fri Oct 12, 2007 8:44 pm
If the rotor is not turning, it really does not matter where it is sitting now.
Just pull it out and take a look at the gear.
With a failed distributor gear or timing chain, you will be re-setting the distributor's position either way.
 Post subject: Base Timing
PostPosted: Sat Oct 13, 2007 7:58 pm
Ok, it was the gear and I got all the pieces. I have a new one on the way. So how do I do the timing once the new gear and roter are back in. I have heard something about base timing?
Thanks
Jeff
PostPosted: Sun Oct 14, 2007 10:33 am
My method for establishing base timing.
Remove valve cover.
Install bolt in forward end of crank to aid in cranking.
Remove coil wire on coil end
Rotate crank while watching #1 cyl intake rocker. Continue rotating until you see the intake valve fully closed. Look and see if timing mark on damper is near timing tab. Get it as close as possible to your target base timing (mebbe 5 BTDC).
Put the distributor in the hole with the rotor pointing toward #1 (look on the cap)
With the key on rotate the distributor back and forth till you get a spark from the coil wire( or #1 spark wire)
Clamp the dist down, replace the coil wire and fire that baby up....fine tune the timing with a light.
Set the valves and replace the valve cover.
Extensive burnout testing recommended. You are looking for at least 30 ft from both tires. :wink:
PostPosted: Sun Oct 14, 2007 11:44 am
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Sun Oct 14, 2007 11:54 am
it is good to know that this is an acceptable method.
and it works GOOD !!!
regards,Rod :twisted:
 Post subject: Thanks for the help.
PostPosted: Mon Oct 15, 2007 6:38 am
Thanks for the help. Love the thirty feet burnout. I can get that with my VMAX but not sure with the Demon just yet. :D
PostPosted: Mon Oct 15, 2007 11:04 am
I had a problem with my 63 Dart w/ a 72 225 that was breaking distributer gears left and right. It turned out being a bad distributer. Put a new one on, and I haven't had a problem since. So, if you break another gear, you might want to think about getting a new distributer. I got mine at AutoZone for less than $50.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Oct 15, 2007 6:51 pm
I think the one that broke was the original, but if it keeps happening I will definitely keep that in mind.
thanks
PostPosted: Tue Oct 16, 2007 6:46 pm
If you'd like Im having a friend who "has an Uncle " that makes gears make me some iron gears. If it works out Ill tell you and get you one made up if you want one.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Fri Oct 19, 2007 8:56 pm
The only time that the 68 Valiant I had ever left me stranded was when the distributor gear broke. The distributor was a junk yard one that I had gotten when I converted it to electronic ignition. It lasted about 2 years. Put a new one in and no more problem. After converting to electronic ignition no more setting point blindfolded.
Former bent 6 owner
Mark
