It is currently Fri Nov 20, 2026 6:07 am
PostPosted: Sat Oct 13, 2007 8:15 am
when my parts houses started delivering me autolites MADE IN CHINA in big letters on the box
Another one bites the dust :-(
PostPosted: Sat Oct 13, 2007 8:53 pm
Maybe they were counterfeit.......... :cry:
PostPosted: Sat Oct 13, 2007 11:22 pm
Entirely possible. It's happened with AC and NGK plugs. The Chinese have no qualms about violating patents, copyrights, etc.
PostPosted: Mon Oct 15, 2007 11:40 am
I called autolite, and left a message. They called back today.. I was told that none of their plugs are made in China. They are probably counterfit.
Ron, if you still have a box or plug, call Lisa at 1-877-250-8361. They would like to hear from you first hand. They were unaware of the counterfit plugs.
PostPosted: Mon Oct 15, 2007 11:09 pm
Check out this NGK plug... 2477 ZFR5FIX-11 tapered ground electrode. About the same price as the 7781, ~ $7 - they have a version with iridium tip and platinum ground but thats more then $11.
PostPosted: Tue Oct 16, 2007 7:59 am
The ZFR5FIX-11 does have an ultra-fine (0.6mm) iridium centre electrode, a corner-clipped side electrode and a gap of 0.044". It costs about 37¢ more per plug than the ZFR5LP-13G, which has platinum tipped centre and ground electrodes. Either should last a lonnnnnnnnnnnnnng time in a Slant, even with a high-juice DIS driving it.
PostPosted: Fri Jul 17, 2009 4:08 pm
That might've been true back in October '07, but it might not have been true. Every new box of Autolite plugs I've seen in at least the last 6 months, from Seattle to Toronto, has been clearly labelled "MADE IN CHINA". On the outer box and on the inner box. They're not counterfeits. Counterfeits of an American-made product would say "Made In USA", not "Made In China". Kind of like a counterfeit $20 bill doesn't say "Twenty Counterfeit Dollars". I think Ms. Lisa was probably telling the truth as far as she knew it, but I don't think she knew very much. It's plain to me that production of most (all?) Autolite plugs has been moved to China.
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
