It is currently Wed May 27, 2026 1:00 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Tue Oct 16, 2007 6:07 pm
Here is my hy35 and h1c (there are different versions of h1c)
the h1c is a bit bigger than the t3 turbo from a nissan 300zx which is 3.0l
it will work but I think that a hy35 should be better
if you have the h1c use them!
at http://www.turbomustangs.com/smf/index. ... ic=52334.0
on a v6 3.8l mustang with a hy35 starts boost at 1800 and full boost at 2100 since a slant is smaller it will boost later on which should be perfect
the hy35 comes with a 9cm exhaust
the hx35 comes with a 12cm
the h1c i have comes with a 16cm I am looking for a 12 to put on it so I can use it on smaller engine
I have everything for a carb blowthru on a slant but I am going to leave it alone and just drive the car and use all the turbo stuff on a datsun l28 6 cilinder engine
http://www.cardomain.com/id/lncognito
PostPosted: Wed Oct 17, 2007 5:32 am
this is what I've been able to measure from a Schwitzer 4LGZ
intake side goes from 78mm inlet to a 65mm outlet
the flange is 90 x 50 mm and the exhaust outlet is 90 mm
Juan Ignacio Caino
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 9 guests
