It is currently Mon May 25, 2026 2:41 am
 Post subject: which alternator???
PostPosted: Fri Oct 19, 2007 4:16 pm
i am gathering parts for my slant into a 40 plymouth project. i have 3 engines, 2 transmissions, but no alternator yet.
it appears that they used several different alternators through the years.
what would you guys recommend as a good alternator/regulator setup for the car. are they all interchangable? looks like i will be using the 1966 engine and brackets, so i will need one that will go on there.
in theb past i have liked the g.m internal (1 wire
0 setups on my chev. engines, and would prefer to stay with something on that order in the mopar line.
any feedback will be appreciated.
thanks in advance,
Chuck
PostPosted: Fri Oct 19, 2007 4:59 pm
All the Mopar alternators are externally regulated. Same general housing style and same physical fitment from '60 to '87, with minor differences not affecting physical interchangeability in '62, '70, '72, and '79. Regulation system is '60-'69 vs. '70-up. The '70-up alternators are easier to find these days and the regulation is superior. '70+ alternators can easily be used with pre-'70 regulators. Here is a brand new one from a reliable vendor.
'89+ Mopars use Nippondenso (smallest/lightest), Bosch, or Chrysler (largest/heaviest) alternators, all physically interchangeable. All compatible with '70+ regulator. Minor bracket mods permit this alternator to be mounted on earlier brackets.
See also this thread.
PostPosted: Fri Oct 19, 2007 5:25 pm
thanks dan,
you are a big help as usual.
Chuck
PostPosted: Fri Oct 19, 2007 5:48 pm
can i use the newer style
1970-89) electronic regulator with the older 60's early 70's alternator?
thanks,
Chuck
PostPosted: Fri Oct 19, 2007 6:32 pm
No, that's a direction you can't go; you have to use the '60-'69 type regulator with a pre-'70 alternator. But, there are electronic regulators for the early applications. The good ones are NAPA Echlin VR-1001 and Standard-BlueStreak VR-128.
PostPosted: Sat Oct 20, 2007 8:06 am
dan,
that was a great link. although the alternator issue is a long way from now, i'll have time to hash it over. i like the adapter that is out there from that link to install the delcotron on the car. guess i can't completely get the g,m blood out of me, as i hane worked with those for years. they are reasonable price, and the 1 wire hookup really cleans up the engine wiring.
thanks again
Chuck
PostPosted: Sat Oct 20, 2007 8:10 am
I wonder if it would be worth trying using my original '66 regulator with my new Bosch alternator, or is this taking the swapping a bit too far?
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Oct 20, 2007 9:38 am
Which Bosch alternator are you running?
PostPosted: Sat Oct 20, 2007 10:58 am
so i have found a alternator from a 70 340, this would reguire the 70 and up electronic regulator. the guy that has it calls it a (round back?)
Chuck
PostPosted: Sat Oct 20, 2007 1:34 pm
A '70 alternator can be used with either type of regulator. If you use the '60-'69 type regulator, you connect one (either) of the alternator's two field terminals to ground. All Chrysler alternators through '71 use pressed-in diodes and the rear housing is rounded in profile. Starting in '72 they used screwed-in diode trios in a squared-out portion of the rear housing; these are referred to as "squareback" alternators.
PostPosted: Sat Oct 20, 2007 6:15 pm
I'll be fitting in a 120 amp alternator from a '89 pickup. Already swapped on the pulley and ground down the bracket, just need to wire it up correctly.
PostPosted: Sat Oct 20, 2007 7:50 pm
A good-quality ordinary '70-up regulator will work just fine.
PostPosted: Sun Oct 21, 2007 6:38 am
Thank you; I thought it might be a good idea to ditch the points-type regulator.
PostPosted: Sun Oct 21, 2007 6:54 am
Well, even a points-type regulator would run that alternator if you picked a sturdy enough version of the points-type regulator (NAPA Echlin VR-34 or VR-35). But yeah, better to go to the '70+ unit.
 Post subject: Ammeter....
PostPosted: Sun Oct 21, 2007 12:31 pm
Are you going to run an ammeter or voltage gauge?
It gets tricky running the ammeter with higher output alternators........
