It is currently Thu Jun 04, 2026 5:42 pm
 Post subject: Radiator Cap? (1979 225)
PostPosted: Fri Oct 19, 2007 6:38 pm
NAPA has a 16 lb. cap part# 703-2447. Does STANT manufacture NAPA/Balkamp radiator caps. This one says,"assembled in Mexico" I hope it's a STANT. Does anybody know? THANKS MUCH!!
PostPosted: Fri Oct 19, 2007 6:52 pm
Whether the cap is appropriate depends on the specs of your car. Where do you live (hot/cold climate)? Does your car have A/C? Stant used to make NAPA's caps, but the last time I checked was years ago. Chrysler's own caps are Mexican-made.
PostPosted: Fri Oct 19, 2007 6:58 pm
t LIVE IN mINNESOTA, No A/C. Bone stock motor. Thanks for the quick reply.
PostPosted: Fri Oct 19, 2007 7:31 pm
13-pound cap is plenty for your application, and will place less stress on your cooling system. Use a Stant 10229 (regular) or 10329 (lever-lock) cap, or equivalent from NAPA.
