It is currently Wed Jun 03, 2026 5:08 pm
PostPosted: Fri Oct 19, 2007 5:52 pm
Hi
I have a 1981 Dodge D-150 Pickup, and I have re-installed the vacuum hoses. I have a Holley 1945 carburetor. I was wondering what all goes to the vacuum tree. I do not have power brakes or air conditioning, and according to the vacuum diagram on the fender, no hoses from the vacuum amplifier go to the vacuum tree. I know the cruise control goes there and also one of the ports on the carb goes to it. I had to replace the previous vacuum tree (four ports) because it broke. Any ideas on the other two smaller ports?
Thank you for any help,
David
PostPosted: Fri Oct 19, 2007 6:35 pm
Unused ports simply get plugged with a quality rubber vacuum cap. There were manifold trees with various numbers of ports, not all of which are necessarily used on your application. There should be a vacuum hose from the manifold to the EGR vacuum amplifier.
PostPosted: Fri Oct 19, 2007 6:56 pm
Thats what I thought. On all the diagrams i seen online it is . The diagram on my truck shows one hose (white stripe) goes to egr.
One hose (yellow stripe) goes to carb , and one hose (orange/red stripe) goes to side port on vacuum solenoid . just another question Dan , on the diagrams I have seen online the front port on the vacuum solenoid that sticks straight out say bleed . Does that mean cap it ,leave it alone ,or do something with it.
Thanks
Dave
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 11 guests
