It is currently Wed Dec 31, 2025 11:03 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
 Post subject: Re: Ammeter....
PostPosted: Sun Oct 21, 2007 12:57 pm
It gets tricky running the ammeter with higher output alternators........
Yeah, you get to pick either the pre-'70s OE type that works well but has a relatively low current limit before things start burning up, or the post-'70s OE-type that has a high current limit and doesn't work! :shock: There are good aftermarket ammeters, and there are various ways of building an "active shunt" that protects the early-type ammeter from overcurrent...
PostPosted: Sun Oct 21, 2007 2:21 pm
Are you going to run an ammeter or voltage gauge?
Ammeter, with a diode shunt. It's trickier still to make a voltmeter look like my original sideways-mounted ammeter.
If I were completely redoing my dash, I might consider a voltmeter (or an aftermarket ammeter). But I'm leaving the stock dashboard in at the moment, and don't like the idea of a dead gauge in the dashboard.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun Oct 21, 2007 2:24 pm
I approve! :lol:
Users browsing this forum: Ahrefs [Bot] and 11 guests
