It is currently Mon Apr 27, 2026 3:37 pm
 Post subject: poor man's turbo
PostPosted: Sun Oct 28, 2007 3:39 pm
Well, impatient man turbo
say I wanna experience with turbo my existent motor, while I finish the car and can start another idiotic money pit and build the 4.120 stroke 91 mm bore slant,
can I get away with non-forged pistons?
do I have to O-ring my block?
big turbo like Holset HY31 - Garret GT4088R (AR 5.0 is about the same size, BIG turbo for up to 4 liters engine and 600 hp)
I just want to blow ANOTHER engine before I build the big cubes slant.
Juan Ignacio Caino
PostPosted: Sun Oct 28, 2007 4:27 pm
I'm putting a GT4082 on my internally stock slant six. We'll see how it holds up. I've heard of slant sixes running 10 psi of boost on stock internals before.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun Oct 28, 2007 4:31 pm
Try 21psi. Thats what I'm running on my 100% stock slant. Watch the afr.
PostPosted: Sun Oct 28, 2007 4:42 pm
I plan on running a 600 CFM holley 4160. I'll jet it "safely" :wink:
shaker223, what are you using as in total timing, cam timing, ignition, etc etc?
Juan Ignacio Caino
PostPosted: Sun Oct 28, 2007 5:48 pm
See here for the specs.
http://www.slantsix.org/forum/viewtopic.php?t=24937
For my combo, I've found 19* of total timing to be the best. I tried 16* to 21* (verivied on a chassis dyno) and the gains from 19* to 21* were not worth it.
PostPosted: Mon Oct 29, 2007 1:52 am
afr
What's that?
PostPosted: Mon Oct 29, 2007 1:58 am
Air Fuel Ratio.
Nevermind... :oops:
