It is currently Fri May 15, 2026 2:47 pm
PostPosted: Thu Aug 16, 2007 12:01 pm
Out of curiosity, I read over the EPA pages and as I read it it is legal under fed law to go from R12 to R134a, and legal to go from R134a to HC, but illegal to go from R12 to HC.
I checked Virginia law and it is a $30 fine for using HC in an automotive AC system. VA has lots of odd little laws.
There are a few loopholes in the law. You are correct in your reading, that is how some of these "non approved" refrigerants get by. They are not approved for retrofit from R-12, but are ok for retrofit from R-134a. So if a vehicle is changed from r-12, to 134a, first, it can then be changed to the non approved refrigerant.
There are many states that have laws against hydrocarbon refrigerants, in motor vehicle use.
My personal opinion, is, use only R-12 or R-134a in a MVAC. Main reason, is, component warenty. Warenty with any manufacturer I know of, is only good when used with R-12, or R-134a.
PostPosted: Thu Aug 16, 2007 1:06 pm
Yup, and those loopholes are exploited to the max by the marketeers of hydrocarbon refrigerants, along the lines of "Warning, caution, check your local laws (wink, wink) before using our stuff to replace R12! (nudge, nudge, wink) Our stuff may be used to replace R134a freely (wink, hint hint), so if you have any doubts about the legality (ahem, cough) of our stuff, you will want to convert your vehicle to R134a and then put our stuff in (wink)." It's a crock. And just because there's no Federal law at the moment against using explosive refrigerants in place of R134a, doesn't mean it's OK or a good idea. Just means it's not Federally illegal. As Charrlie_S mentions, many states have laws against hydrocarbon refrigerants in motor vehicles...for a very good reason.
That's one good reason. Another: When your A/C breaks and you're away from home, or you don't have time or space or knowledge to do the repair yourself, a system charged with anything but 12 or 134a is going to be considered "contaminated" by most any shop. If you're lucky, they'd agree to work on your car and charge you a very hefty decontamination fee. It's an expensive damnuisance for them when they have to use their equipment on a contaminated system, so it's reasonable and proper for them to expect the customer with such a car to foot the cleanup bill.
More likely, though, they will simply refuse your business.
PostPosted: Wed Sep 05, 2007 3:44 pm
A/C is still working fine.
PostPosted: Mon Oct 29, 2007 9:40 am
This is the last time I'll post on this thread, but the a/c is still going strong. And Dan, if this makes me selfish get a load of this- I use two ply toilet tissue. I'm so ashamed of myself. I should'nt have written that. Oh well.
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
