It is currently Wed May 20, 2026 8:40 am
 Post subject: Kreen- Recommened usage?
PostPosted: Tue Oct 30, 2007 4:24 pm
I would like to try this but don't know how much to order.
How much do you add to oil and how long do you leave it in? Do you just run it thru like a motor flush before oil change or can you sub say a quart for a quart of oil at oil change and just leave it till next oil change? Also how much do you add to fuel system?
I realize that most of this info is probably on the can, to bad its not on their website so I would know what to order.
Thanks Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Tue Oct 30, 2007 4:35 pm
Kreen's very good stuff. I would probably use it as a final step after running through my soup recipe. I would definitely not just dump it (or any other "engine flush") in, in any proportion with oil.
PostPosted: Wed Oct 31, 2007 4:24 pm
Thanks Dan for the info.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
