It is currently Mon May 25, 2026 3:02 pm
PostPosted: Tue Oct 30, 2007 11:11 am
would like to know the info on these. If i post some pics of the cast #'s can we figure out the years etc?
I'm trying to sell these and would like that info, ty
PostPosted: Tue Oct 30, 2007 2:05 pm
hello,
are these slants the SAME ones that were on ebay back in July? were they yours then,or did you buy them.
one is reverse rotation IIRC.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0153697675
regards,Rod :?
edit:
answered my own question.they are yours and the same beasties.
perhaps no one wants a slant capable of 100 mph in reverse.
http://cgi.ebay.com/ebaymotors/Fresh-PA ... 0153697675
PostPosted: Tue Oct 30, 2007 2:56 pm
good eye mate.... regardless, wheres the resource to figure out what i have. We got these off of a bad deal from a guy in LA. we don't know anything other than what we can read off the motors. I would like to figure out the year, therefore the rated HP for that year with the stock carbs for it's particular app.
PostPosted: Tue Oct 30, 2007 3:10 pm
It would be a good start to post whatever-all you can read off these engines. Post casting numbers and engine ID numbers (which will either be stamped or will be on a data plate).
PostPosted: Tue Oct 30, 2007 4:02 pm
Reverse rotation is done with a camshaft. That basically about it, IIRC.
Cheers, Wizard
PostPosted: Tue Oct 30, 2007 4:09 pm
you're right, should have
Case Numbers: 030-14 0996 AAWJ & 030-11 1906 AAWJ
Head Numbers: 3698447-1 & 3698447-2
PostPosted: Wed Oct 31, 2007 10:21 pm
I found one website that listed the 3698447-1 head as a 1975-80 plymouth.
PostPosted: Thu Nov 01, 2007 12:50 pm
Looks to be late 1970s cast crank engines.
As already noted, the reverse direction and marine specific items are what sets these engines apart from the pass. car version of the SL6.
As for all the other items, they are the same as any other SL6 made in the late 70s.
