It is currently Wed Apr 09, 2025 2:48 pm
PostPosted: Fri Nov 02, 2007 11:29 pm
man i feel like a total dumb a** for asking this question, it's been 6 years since i oil changed a slant 225.
its 5 quarts of oil right?
PostPosted: Sat Nov 03, 2007 12:34 am
According to my factory service manual 4 quarts but I'm assuming your replacing the filter so it says add 1 quart for that.
easiest way to remember it's 5 quarts is that every motor other then a hemi is 5 quarts of oil. 170, 198, 225, 273, 318, 340, 360, 361, 383, 400, 440 is all 5 quarts of oil
PostPosted: Sat Nov 03, 2007 1:03 am
Even with a big filter mine only took 4 1/2 quarts. Infact I only put 4 quarts in and the oil is in the middle of the marks. It could take another 1/2 quart to put it exactly on the full mark but I left it as it was.
Jess
PostPosted: Sat Nov 03, 2007 7:25 pm
Was that before, or after the engine was ran?
PostPosted: Sun Nov 04, 2007 6:09 am
FYI My 360 in my van takes 6 1/2 qts. stock. What is scary? The factory endine with 97K on it had some much crud in it 5 said full on the stick :shock:
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
Users browsing this forum: Ahrefs [Bot], Bing [Bot], slantsik and 7 guests
