It is currently Thu May 14, 2026 5:48 am
 Post subject: intake number
PostPosted: Mon Nov 05, 2007 10:53 am
Hello, Does anyone have a link to listing of slant six casting numbers? I have tried multiple sites but all are for 8's. I have a intake # 4041043. I am trying to get info on it as it was given to me. Yes it is a supersix setup all was included but there was no info i.e. year, carb #. I need info to cleanup and install. The carb is main problem as it has no tag # so I thought if I can get year of intake from casting info it may help. I'm pretty sure carb is a Carter BBD. Thanks for the help.
PostPosted: Mon Nov 05, 2007 11:05 am
Casting number info won't help you with carb ID...you'll get quicker/better info if you'll post some good, clear, sharp pictures of the carburetor from multiple angles, and tell us if your intake is made out of aluminum or iron.
PostPosted: Mon Nov 05, 2007 4:21 pm
Thank you, I will take some soon and post. Thanks for your time.
 Post subject: # 4041043
PostPosted: Mon Nov 05, 2007 5:47 pm
That casting number is the super six iron intake from the late 70's (I should know I got a few being door stops in the garage next to the 1 barrel buddies from various years...
Hope the BBD still has it's tag, or hope it doesn't have a sticker on it (stickers are usually a remanf, Tomco, Holley II, etc...)
PostPosted: Mon Nov 05, 2007 6:03 pm
Thanks D, It puts me at a reference point. Thank you. The carb has nothing on it but casting #'s for the various components. Is the manifold ok to use. I have a 225 all stock except electronic ig, Dutra duals. I am building a 66 Dart Gt with my 12 yr old. 6 months ago it was in pieces now it is on the road and reborn. Any advice is appreciated as this is my first Mopar build. I just want to add a little pep to motor. Thanks
 Post subject: Good part...
PostPosted: Mon Nov 05, 2007 6:13 pm
Yeah, just make sure if you use it with another exhaust manifold to get the parts mated and milled at your local competent machine shop so they are 'flat'... I don't use the aluminum version since it can be full 'o holes (porous)and the cast iron versions when i come across them, are cheap enough...
Good luck on your project, if you want to get wild, check the slixer's gallery for 66Dart's setup, that'll keep you motivated...
PostPosted: Mon Nov 05, 2007 6:59 pm
Thanks D, WOW!! That 66 looks fantastic! My compliments to you and the owner. Thank you for your time and I hope in the near future i can post some pics of our Dart. I can't go that wild as my main goal is to teach my son the basics of building and maintaining a car. We have so far rebuilt tranny, rebuilt entire suspension, gutted and rebuild all interior except painted parts. People like yourself on this forum have been a GREAT help to us and we thank everyone. I will use your advice and once again show my son the kindness you have shown with your responses to our ?'s. Thanks again
