It is currently Tue Apr 22, 2025 2:39 am
 Post subject: No Brakes!
PostPosted: Tue Nov 06, 2007 10:20 am
Ive been away at work for the last few months. Got home, jumped in the Volare & she fired right up! Running great.
Went to go for a lil spin & I noticed that the brake pedal now goes alllll the way down! I can get just a lil bit of braking action.
Havent popped the hood yet. Ill take a look this afternoon.
S.
1980 Volare Slant
PostPosted: Tue Nov 06, 2007 2:46 pm
Well the resevoir is pretty much empty. Im gonna top it up then try to find the leak...
S.
1980 Volare Slant
PostPosted: Tue Nov 06, 2007 4:05 pm
May have to take the drums off if nothing is obvious.
PostPosted: Tue Nov 06, 2007 9:39 pm
I got it filled & its a lil better, but I cant see any leak when i pump the brakes... Have to pull a tire off when I get a chance
S.
1980 Volare Slant
PostPosted: Tue Nov 06, 2007 11:08 pm
Which reservoir was low? IIRC the larger rearmost one feeds the front brakes.
PostPosted: Wed Nov 07, 2007 8:30 am
They both were, but the rear one took a few times to top up. I definately got some feel back, but they need to be bled down.
S.
1980 Volare Slant
PostPosted: Tue Nov 13, 2007 5:22 pm
empty? or pretty much empty? if u sucked up air, i would bleed the brakes, remeber that fliud will go down as pads and shoes wear... may not even be a leak...
