It is currently Mon May 04, 2026 4:57 am
PostPosted: Sat Nov 10, 2007 7:35 pm
IF YOU GO WITH THE LOWER RATIO 998/999 1ST GEAR IN A 904 WON'T THE NEW 1ST TO 2ND WIDER RPM DROP PRETTY MUCH ELIMINATE ANY GAIN IN 60 FOOT TIMES? Can the Slant recover from such a wider drop?
I HAVE MY TRANS ON THE BENCH AND AM CONTEMPLATING WHICH GEAR SET TO PUT BACK IN.
THANKS :D
TERRY
Terry Bogusz
From Super 6 Left turns to Straight again.
PostPosted: Sat Nov 10, 2007 7:43 pm
I the 2.74:1 first gear transmissions had a 1.54:1 second gear as opposed to a 1.45:1. The FSM has the ratios.
PostPosted: Sat Nov 10, 2007 7:58 pm
The wide ratio is not that noticable when you have a high stall converter and a deep rear end ratio. :twisted:
PostPosted: Sat Nov 10, 2007 8:16 pm
The big drop is between 2nd and 3rd. :shock:
No, it will not recover. You will gain ET down low and give it back at the big end. :(
Been there, done that, got the T-shirt. :roll:
It is fun for stoplight racing though. :twisted:
 Post subject: Slant recovery
PostPosted: Sun Nov 11, 2007 7:23 am
With an engine limited due to our head restrictions (flow and saimeze port heat transfer) to 6700 max. I believed the beginning of the peak torque band would be missed (came in too far below) with the shift/rpm drop. Thanks for the info.
I'm looking at a 3600 stal convertor and for 1/4 mile a 4.30 gear.
This is a 10" slick car.
:) Thoughts?
Thanks
Terry
Terry Bogusz
 Post subject: Re: Slant recovery
PostPosted: Sun Nov 11, 2007 9:39 am
:) Thoughts?
Thanks
Terry
How tall of a tire?
I am gonna try a 4.56 with a 28X9X15 slick and a 4000 converter.
PostPosted: Sun Nov 11, 2007 10:09 am
and a 400 converter.
I don't think your engine will idle that low. :lol: :lol:
PostPosted: Sun Nov 11, 2007 11:21 am
Sure it will. I have an extra tight converter for spray ya know whut I'm sayin'? :lol: :lol: :lol: :lol:
PostPosted: Sun Nov 11, 2007 5:10 pm
OOPS...
Should have used the Spell Check........
Terry Bogusz
PostPosted: Sun Nov 11, 2007 5:12 pm
Same size tire I'm looking at.
Also for the Daytona body I'm using now it will look :shock: a lot better.
What kinds of trap RPM's do you expect?
Terry
Terry Bogusz
 Post subject: low gear set
PostPosted: Tue Nov 13, 2007 3:21 pm
I have used both and prefer the standard gear set. We use a 5000 converter,4.30 gears, and 26" tall drag radials ( MT 235/60/15 ). Car with driver about 3000 lbs.
 Post subject: 904 - 998/999 mods
PostPosted: Wed Nov 14, 2007 7:37 am
The proposed car is to be right at 2600 lbs with driver.
Thanks to all, :wink:
Terry
Terry Bogusz
PostPosted: Thu Nov 15, 2007 10:07 am
I am shooting for going through the traps at 62-6300. My car is considerably heavier than yours. :lol:
