It is currently Fri Oct 23, 2026 6:53 pm
 Post subject: Sick Six
PostPosted: Tue Aug 13, 2002 10:47 am
The 1970 Dodge Dart starts well, and idles well, but has no power past 50 mph. We replaced the timing chain, and timed the engine (about 10* BTDC). The carburator has been replaced, along with plugs, coil, points, and wires. It ran great once, and now is back to its rough run at any speed but idle. Any suggestions would be appreciated.
bombcar@petrus.thomasaquinas.edu
 Post subject: Re: Sick Six
PostPosted: Tue Aug 13, 2002 3:55 pm
Did you degree-in the cam when you changed the t. chain?
Is the mechanical advance working, what it the total advance?
Cam Degree Check
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 22 guests
