It is currently Fri Oct 23, 2026 6:55 pm
 Post subject: turbo slant help
PostPosted: Thu Aug 15, 2002 10:21 am
hello slant guys:
i am trying to build a blowthru slants 6 (225cid)here in mexico but i want to set the engine with the stock crank and rods, but i`m using the 2.2L turbo pistons because i read that they are better to stand the heat than the 225 stock piston. my problem is that the 2.2l piston is a bit shorter thant the 225 and that makes my CR too low, but i though that is i put a 198 road the CR incrises.
the big problem is the 198 engine wasent buid in mexico. I was wondering is any of you guys have a spare set of 198 rod for sale and how much would they cost to ship them here.
ernestoft74@yahoo.com.mx
 Post subject: Re: turbo slant help
PostPosted: Sat Aug 17, 2002 9:41 pm
Did you find the rods you were looking for?
ahtoews@shaw.ca
PostPosted: Sun Aug 18, 2002 10:42 am
: Did you find the rods you were looking for?
No i did not. I milled the blok .100 inch. but I have another project in mind that could use the 198 rod. do you have a set?
 Post subject: Re: 198 connecting rods
PostPosted: Sun Aug 18, 2002 10:59 am
: No i did not. I milled the blok .100 inch. but
: I have another project in mind that could
: use the 198 rod. do you have a set?
There is a set of 198 con rods selling on ebay now and a source for them listed in our parts data base.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 23 guests
