It is currently Sun May 17, 2026 11:47 pm
PostPosted: Mon Nov 19, 2007 3:01 pm
Guys
I have a '66 904. It is nothing unusual, but I am wondering if it goes directly into 70's slants...the input shaft looks like a 23 spline one on a 833 so maybe 70's would need the bearing into the crank end like the 833 does?
thanks
rock
'64d100
PostPosted: Mon Nov 19, 2007 3:21 pm
A '67 or earlier Torqueflite can be used behind a '68-up slant-6 as long as you install the 1/8" annular adaptor ring in the '68-up crankshaft's counterbore. This can be had from Pat Blais, tflitepatty@verizon.net.
On the other hand, a '68 or later Torqueflite will not go behind a '67-down slant-6 unless you either have a custom "small nose/large input shaft" torque converter made, or install a fair number of '67-down parts in the late transmission.
be
 Post subject: Thanks a million Dan!
PostPosted: Tue Nov 20, 2007 6:42 am
Dan,
Thanks a million! Other than the 727 I just put in , this 904 is the only automatic I ever had...in anything, ever. I am just not up on them. What you are reporting confirms what my eyeball tells me but my eye isn't what it used to be 40 years ago! I will file this away to help a fellow slanter who may be able to use the tranny.
rock
'64d100
PostPosted: Wed Nov 21, 2007 5:37 am
You must use the correct converter, when swapping transmissions. Early trans reqires early converter, and late trans requires late converter. The input shaft spline count changed, between the early and late.
