It is currently Wed Nov 25, 2026 12:10 pm
PostPosted: Fri Nov 23, 2007 11:02 am
I've got a pedal assembly and z-bar from a '65 Dart, wondering if they will both fit in my '69 cuda? Both are for small-block. The z-bar to frame rail ball stud looks different, has a plate mounted to it rather than just a screw-in ball stud. Thanks,
Bill
69 fb
Hillsboro, OR
PostPosted: Fri Nov 23, 2007 2:20 pm
The 65 stuff will fit only the early A Body. You need the stuff from the 67-69 A body. Possibly the 70-76 stuff might work as well but am not sure about that.
 Post subject: That will work...
PostPosted: Fri Nov 23, 2007 4:51 pm
Yep...I just put a 1974 A-230 in my '67, I used a 1976 Z-bar, a set of pedals from a '73, and the linkage was from a '74 (with new bushings, etc from Brewers). Everything bolted up just like it was meant for that car...
PostPosted: Fri Nov 23, 2007 9:37 pm
Thanks guys - much obliged for the help! Will let you know how it works out.
Users browsing this forum: Amazon [Bot] and 3 guests
