It is currently Tue Apr 28, 2026 7:56 pm
PostPosted: Mon Aug 19, 2002 6:30 pm
hey all,
well got a new clutch and all and wonderin what the specs should be to torque the pressure plate to the fly wheel. thanks
Justin
slantsickness@hotmail.com
PostPosted: Mon Aug 19, 2002 7:36 pm
my book says 55 ftlbs
: hey all,
: well got a new clutch and all and wonderin what
: the specs should be to torque the pressure
: plate to the fly wheel. thanks
: Justin
PostPosted: Tue Aug 20, 2002 8:20 pm
: my book says 55 ftlbs
Are you sure about that? I don't know for positive, but 55'#'s seems like alot for those little bolts. If you were referring to the flywheel to crank bolts that'd seem about right.
fglmopar@aol.com
PostPosted: Tue Aug 20, 2002 8:55 pm
: Are you sure about that? I don't know for
: positive, but 55'#'s seems like alot for
: those little bolts. If you were referring to
: the flywheel to crank bolts that'd seem
: about right.
It is... good call Bud.
Clutch Cover to Flywheel specs:
5/16" bolts = 200 in/lbs
3/8" bolts = 30ft./lbs
Flywheel Bolts = 55 ft/lbs
PostPosted: Wed Aug 21, 2002 4:29 pm
OOPS!
I need to get some more sleep or something. I looked at the flywheel to crank. SORRY
: about right.
