It is currently Sat Jun 20, 2026 3:18 pm
 Post subject: Carb Problem
PostPosted: Mon Nov 26, 2007 11:12 am
when I get into about third gear it will start to miss and the faster I go the more it misses. If I slow it down a bit it will go back to normal. My carburetor is very old and already has problems accelerating, could this be the problem? HEI with mopar distributor and ACCEL 8140 Coil. New plugs set to 45 gap. 10 degrees BTDC.
PostPosted: Mon Nov 26, 2007 11:15 am
When I put in the new fuel pump there was a old O ring in the fuel valve at the carburetor, it was in pretty bad shape and was leaking fuel all over the place. I took it out and it stopped leaking, but I bet that O ring worked like a shim on the valve and kept it farther out, am I right? Maybe Im not getting enough fuel in the carb
PostPosted: Mon Nov 26, 2007 11:26 am
Did you make these changes after you switched to HEI, or before?
Also, HEI modules tend to misbehave if you have the distributor pick-up coil wired in backwards.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Nov 26, 2007 11:40 am
At first I thought it was related to HEI since it sounds like spark failure, but It may also be not enough fuel in the carb. I suspect not enough fuel since it started doing this right after I replaced the fuel filter, and the broken seal on the carb fuel valve. It was running with HEI perfectly before this.
PostPosted: Mon Nov 26, 2007 4:49 pm
I was right with the cause of the problem, so how high should the float go when it cuts off fuel flow?
PostPosted: Mon Nov 26, 2007 5:04 pm
What type of carb.? That may help. :wink:
Also, I think that part number for your Accel coil is for a points type ignition. I'm not a huge fan of Accel coils, I like and run an MSD Blaster II two with their .8ohm resister (that you of course don't need). If you still have a misfire after adjusting your float level, switch coils with a coil made for electronic ignition and see what happens.
PostPosted: Mon Nov 26, 2007 5:08 pm
1920, the accel is universal
PostPosted: Mon Nov 26, 2007 5:41 pm
Oh, well for a 1920 the top of the float (flat part) should be parallel with the top opening of the float bowl. Its easier with the carburetor upside down, but you can do it on the engine as long as you use very light upward pressure on the float so you don't push the needle valve into its seat. Do you have any type of gasket for the fuel inlet/needle valve assembly?
PostPosted: Mon Nov 26, 2007 5:42 pm
that gasket started leaking, so when I removed it the needle valve moved in, so should I compensate by adjusting the float or find another gasket?
PostPosted: Mon Nov 26, 2007 5:49 pm
I would find another gasket. However, removing it should not make that much difference unless it was set way low already. You say your carb is old, so just get a rebuild kit and throw at it. They are easy carburetors to do, and you'll get a new inlet gasket. :) If you need help with the rebuild, don't worry. Plenty of people here to help you out if needed!
PostPosted: Mon Nov 26, 2007 5:54 pm
I set the float parallel and will probably get the rebuild kit sometime soon, thanks for the advice.
PostPosted: Mon Nov 26, 2007 6:22 pm
If I were to buy a new carb what would be best for mileage?
PostPosted: Mon Nov 26, 2007 6:38 pm
Get a 1920 Economaster from SlantSixDan. Hopefully he still has some for sale. It is a great carb! I can burn rubber with a posi and still get good mileage. The #57 jet is my all round favorite for spunk and economy. :D
PostPosted: Mon Nov 26, 2007 6:40 pm
what kind of mileage you get with it?
PostPosted: Tue Nov 27, 2007 7:17 am
Look below at the build below my name.
From 22 to 24 mpg, that is (stop and go) city and freeway combined. I haven't taken it on a trip yet to find out what it will get.
