It is currently Fri Jun 19, 2026 7:21 pm
PostPosted: Wed Nov 28, 2007 10:56 am
is there another carb that will fit the same manifold as a 1920 and still be possible to find
PostPosted: Wed Nov 28, 2007 11:30 am
A Carter BBS. I'm still working on finding you a carb, BTW.
PostPosted: Wed Nov 28, 2007 11:54 am
thanks for helping me out. I did make a quick fix to my carb and it works a little better now, it doesn't loose fuel anymore at 45 MPH. I just readjusted the float since a gasket on the fuel valve broke.
PostPosted: Thu Nov 29, 2007 1:15 am
I have an Economaster.... :)
It's all there, but I believe the metering block may be plugged. :( If you have some spares though, it could work. If this is your daily driver though, Dan can get you a carb RTG out of the box.
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Thu Nov 29, 2007 8:23 am
Yeah, Dan's helping me out.
