It is currently Sun Jun 21, 2026 11:51 am
PostPosted: Fri Nov 30, 2007 12:41 pm
I have a '64 D100 with a 3 on the tree 225 /6. The head has been milled .100", ported & polished, new guides, hardened seats, and the engine has the Super six carb, intake and exhaust. What is the recommended redline rpm for this engine? Also, what's a safe cruising rpm for highway driving (long trips)?
Thanks
Stephan Nelle
PostPosted: Fri Nov 30, 2007 1:33 pm
Redline and where it gives up are about the same, about 4000 with a one barrel.
Nice place for cruise is about 2500 to 2700 rpm, right in the middle of the torque band.
PostPosted: Fri Nov 30, 2007 5:11 pm
Cruise rpm will depend on carb size, tire size, rear ratio...
2500-2700 for a 1 barrel
can get as low as 2300 with more carb, gearing, etc...
Redline on a 'worked over engine' is about 5-6K... stock bottom end with old bearings should be about 3500-4000 (don't say I warned ya...)
PostPosted: Fri Nov 30, 2007 7:55 pm
redline?
this is redline
unfortunately the poor ole slant has a bad habit of poking # 5 out. :x
without a good build,if you are looking for max revs,that will probably happen.
seen several over the years. keep it under 4k and (hopefully) you should be sweet.
regards,Rod :D :D
PostPosted: Sun Dec 02, 2007 5:15 am
4000 rpm is about where the power starts to really drop off. I have cruised a well rebuilt stock-internals engine at 36-3800 all the way across the country with no ill effects.
I would say 5000 is totally safe for stock internals if the engine isn't gummed up inside. I was running my V motor (junkyard shortblock) to 5500 road racing and that was 100% fine. BUT, when I went to 6000 redline it gave up.
My '64 Dart motor has a well rebuilt stock-type bottom end with cast pistons and balanced assy and looser bearing clearances and it is good to 6000.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
