It is currently Sun May 24, 2026 3:46 pm
PostPosted: Sun Dec 02, 2007 9:33 am
Is it more important to have the kickdown adjusted so it's fully forward when the throttle blades are closed or fully to the rear when the carb is at WOT? I ask because there doesn't seem to be enough travel at the stud on the carb to have it both ways. I have it adjusted fully to the front and the car seems to be performing well, but I'd like to know the "right way" so I know I'm not doing any damage.
Thanks,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Sun Dec 02, 2007 10:17 am
The correct adjustment has the trans lever all the way forward when the throttle is at the correctly-adjusted curb idle position. You can move it slightly from there to adjust it to your personal preferences.
PostPosted: Sun Dec 02, 2007 10:23 am
Thank you sir!
