It is currently Sun Aug 16, 2026 12:12 am
PostPosted: Sun Dec 02, 2007 12:07 pm
hello everyone,i really need some help with this one!
well the other day my windsheild wipers stopped working.
i pulled the switch and wiring harness it looks good, but what do i know.
i tested the switch with my multi-meter and it works.
when i turn the wipers on i hear the wiper sound (swish swish) but the wipers are not moving.
and since portland is going to have non-stop rain for the next 6 months my car is basically usless with out wipers.
PostPosted: Sun Dec 02, 2007 12:32 pm
Hi Neil,
It sounds like the Wiper drive link has popped loose. Either at the Motor, or where it ties into the connecting link.
 Post subject: Bushing is gone...
PostPosted: Sun Dec 02, 2007 12:35 pm
It's not electrical if you hear the motor turning and can look under the dash and see the motor 'leg' moving... It's usually the link or wiperarm bushings, you can get these at Napa or in the HELP section for your year of car... make sure you put a bit of grease in the cup when you reinstall the link 'nub' into the nylon bushing...
PostPosted: Sun Dec 02, 2007 12:53 pm
ok how do i fix that? or even get to it
PostPosted: Sun Dec 02, 2007 1:31 pm
Yup, almost certainly one or more broken bushings. To get to the bushings, you start removing stuff from under the dash until you have clear access to the wiper links and motor. See this thread for more info.
PostPosted: Sun Dec 02, 2007 5:07 pm
there is going to be nothing orginal left on this car seems like everything is broken. ..... sigh :?
PostPosted: Mon Dec 03, 2007 4:21 pm
im in prtland too, and mine has popped off a few times, just poke ur head under there if u can fit and pop it back on if it hasnt broken
PostPosted: Mon Dec 03, 2007 5:32 pm
well i replaced the plastic connector and tryed in vein to connect it. so i finally got a push nut and cut the plastic connector in half and then used teh push nut to secure it.
ok working wipers ....... only for an hour
right now the passanger side wiper is not working it stoped
prolly the connectors there orginal and quite brittle plastic.
i also replaced my heater hoses with metal flex tubbing and did my thermostat today.
tomorrow i'll finish up teh wiper repair. i was upside down under my dash all day i feel quite light headed. and my hands are very cut up
 Post subject: Pliers..
PostPosted: Mon Dec 03, 2007 6:39 pm
Next time when you try to put the nylon bushing onto the wiper nub, a set of pipelocks/ channel lock pliers (pump pliers...) does help greatly...
-D.idiot
 Post subject: Try this
PostPosted: Tue Dec 04, 2007 11:35 am
Remove the instrument cluster first- it actually comes out pretty easy. Just loosen the steering column so that it hangs down, pop off the speedo cable and wiring harness from behind the cluster and unscrew and pull the whole piece out enough to disconnect the ammeter. make sure you mark the ammeter leads or it will read backwards when you put it back! (you did disconnect the battery first, right?)
Once the dash looks like a huge gaping hole (takes 15 mins!) it is much easier to reach in and pop those suckers on. I used a pair of vise grips to get them seated. I did not know what they looked like or how to grease them when I did it, so now I gotta do it again (squeek-squeek!) but don't worry, it isn't hard.
Might not be a bad idea to buy spares in case they become hard to find soon.
rdr
madam im adam
PostPosted: Tue Dec 04, 2007 2:51 pm
thanks for the advice rdr that would make that a lot easyer. and i have to pull the instrument cluster again aways. looks like rain or shine that's what i am doing tomorrow.
PostPosted: Tue Dec 04, 2007 6:44 pm
Midi,
Makes it much easier to snap in the nylon bushings, if you first place them in HOT water for a couple minutes to soften up a bit. Put a dab of white lithium grease into the "cups" before snapping the linkage together.
By the way, if you haven't already done it, now would be a very good time to replace your wiper pivot seals, since you're that deep into it anyway. Schumacher sells the kits at http://www.engine-swaps.com. It may save you a trip under the dash in the future. :lol:
Jerry
PostPosted: Tue Dec 04, 2007 7:42 pm
thanks for the reminder and great advice jerry! both wiper seals are shot and if it has rained the night before i get a nice leak down my leg when i back out of my driveway.
PostPosted: Tue Dec 04, 2007 9:00 pm
I have gotten by for a few rainy days with a good cleaning and rain-x. As long as you are moving it really helps.
It is a pain but doing the seals and putting it all back together can be done in one evening. The schumacher kit works great and is not at all expensive.
If you get non original clips, I would give them a good look and trim any flashing or burs that will make it hard to get them in. The bushings go in hole and then the pin side gets pushed in.
PostPosted: Wed Dec 05, 2007 5:15 pm
hey i got it done and everything works great!
thanks so much you guys rock my dart!
i keep some aquarium sealant since i breed african cichlids and have a 150G tank. so i used that to seal the wiper leak problem and its holding with wipers working.
