It is currently Fri Jan 02, 2026 5:26 am
PostPosted: Thu Dec 06, 2007 2:11 pm
Obviously there are two TDCs, so if the mark is not visible the first time, turn the engine until the wire goes down and then all the way back up and check again.
Dan,
Either you didn't sleep well last night, or I'm crazy, but there is only one mechanical TDC. For distributor positioning, you are correct.
John
66 Barracuda 225 auto
PostPosted: Thu Dec 06, 2007 2:34 pm
In each cylinder, there is one TDC between the exhaust and intake strokes, and one TDC between the compression and power strokes -- it's that last one you need for distributor positioning.
PostPosted: Thu Dec 06, 2007 5:02 pm
Please correct me if I'm mistaken, but for purposes of checking the timing mark on the balancer it doesn't matter which stroke it's on; TDC is TDC. For purposes of positioning the distributor one must be certain that it is not 180* out. We were talking about checking the marking of the balancer weren't we?
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Dec 06, 2007 5:24 pm
Duhhh...oh yeah!
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
